Shifter Vibration
Old Jun 12, 2005 | 03:41 PM
BrentG's Avatar
Default Shifter Vibration
When i'm on the highway my S2000's shifter vibrates pretty badly, i was wondering if this was normal for our cars of if its just mine that is screwed up, also if you hold the shifter it will stop it from vibrating.
Old Jun 12, 2005 | 03:47 PM
Muz's Avatar
Muz
Former Sponsor
Shifter vibration is par for the course. Don't drive holding the shifter unless changing gears.
Old Jun 12, 2005 | 04:12 PM
Wisconsin S2k's Avatar
yup. vibrating is normal. and as stated, don't hold onto it or rest your hand on it. that can actually cause some abnormal wear.
Old Jun 12, 2005 | 06:37 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've found that a Ti voodoo knob will eliminate it
You could also try an 02-05 knob. It's steel, and heavier. Prolly reduce it...
Old Jun 12, 2005 | 06:40 PM
BigSkinnyS2k's Avatar
why is it bad to hold onto the shifter while driving? how would it wear on stuff when it is in gear
Old Jun 12, 2005 | 07:02 PM
Slows2k's Avatar
If you are putting pressure on the lever while in a gear it can wear on the synchros.
Old Jun 12, 2005 | 10:49 PM
Intrepid175's Avatar
And the shift forks that move the synchros.
Besides, it's generally considered to be good practice to keep both hands on the steering wheel when not shifting gears. If you do keep your hand on the shift lever, I think most of us do at one point or another, just make sure you're not putting any pressure on it.
Drive Safe,
Steve R.
samson123
Nov 3, 2017 09:00 AM
XLeezardx
21
May 14, 2006 08:25 PM
XLeezardx
Jun 14, 2005 09:52 AM
bbrontosaurus
Aug 26, 2003 05:25 PM
