shifter wont go into 5th after regrease
Old Oct 30, 2017 | 04:13 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you are just lifting the shifter in and out without bushing replacement, it cannot be installed backwards.
However, the large plastic bushing can be installed backwards on the shifter during replacement, allowing the shifter assembly to go in backwards.
This will make 5th and 6th hard to find, as the reverse-detent-tab on the shifter is no longer there as a "wall" between 5-6 and reverse.
Old Oct 30, 2017 | 04:16 PM
Soviet's Avatar
Thanks for clarifying.
Old Oct 30, 2017 | 04:31 PM
samson123's Avatar
I'm 90% sure I put it back on the same way that it came out. all the gears work including reverse. the only one that won't go in is 5th.
Old Nov 2, 2017 | 07:14 PM
samson123's Avatar
I figured it out. the new bushings that I installed ended up being cracked. I replaced them with fresh ones, putting them in hot water before hand to insure it would go on the shifter smoothly. Now it works.
thanks for all the help guys. I usually don't post help threads unless I really am stumped. all the comments are greatly appreciated.
Old Nov 3, 2017 | 09:00 AM
windhund116's Avatar
Thanks, for update post. Glad it worked out okay!
sg611
Jul 6, 2019 12:20 PM
BrentG
Jun 12, 2005 10:49 PM
Amer
Feb 15, 2005 03:14 PM
ayelien
Jun 21, 2004 09:27 PM
