Shifting to neutral
Old Apr 6, 2007 | 08:04 AM
jumpman86's Avatar
Default Shifting to neutral
Hi guys,
I have done a search and could not find similar problem.
My car is an ap1 with about 55k miles on it.
The issue is when I shift from 3rd gear or 2nd gear to neutral while slowing down, the shifter seems like it is still in gear while the clutch is pressed. It takes a second or 2 before I can actually take the shifter out from 3rd to neutral.
Is this a common problem for our cars?
Is this the clutch delay that everyone is experiencing?
Thanks for any input.
cw
Old Apr 6, 2007 | 08:32 AM
klee1113's Avatar
dude your problem is like mine and u described it just like i did...
i have the same problem, 04 with 57k miles. you have an ap1, so you dont have a clutch delay valve... i have yet to get responses though... let me know if u find a cause/solution!
Old Apr 6, 2007 | 09:08 AM
raymo19's Avatar
[QUOTE=jumpman86,Apr 6 2007, 12:04 PM] Hi guys,
Old Apr 6, 2007 | 10:04 AM
blackout's Avatar
fluid would be my first thing to check too...something alot of people over look
Old Apr 6, 2007 | 11:09 AM
jyeung528's Avatar
what the hell...
i drove your car and it felt fine...
i said it just felt "notchy"....
should i drive it again?
i didn't feel anything that this guy is describing...
Old Apr 6, 2007 | 11:36 AM
Maskdman3's Avatar
I have had this problem on random occasions. My car is MY02 with 55k miles. I have also had rare occasions where the clutch pedal is on the floor and the gears grind when shifting like I never depressed the pedal. I have to go back to neutral and then pump the pedal.
Old Apr 6, 2007 | 11:48 AM
jumpman86's Avatar
Thanks guys for the input. I have already changed the clutch fluid recently.
Also, I have noticed that if I blip the throttle prior to shifting back to neutral with the clutch pressed, I would not experience this issue.
My thought was that something is still spinning when the issue occurs and I needed to wait a second or 2 before it stops spinning so that the shifter can come back out of gear into neutral without any problems.
Old Apr 6, 2007 | 12:02 PM
raymo19's Avatar
If the fluid is nearly new and the system was bled properly I'm guessing pressure plate.
Old Apr 6, 2007 | 12:35 PM
jumpman86's Avatar
I am not sure if the clutch was bled or just a fluid change. I am guessing it was just a fluid change.
Old Apr 6, 2007 | 02:23 PM
klee1113's Avatar
Originally Posted by jyeung528,Apr 6 2007, 11:09 AM
what the hell...
u drove it around the block.
