should i do a tranny fluid change?
Honda MTF is good stuff and easy to find. I did mine less than 7k miles ago and it still feels pretty good. I'll change it as the shifting feels notchy/clunky/stiff. The manual has a long time interval between changes, but just go on feel.
Most any MTF will be ok in your transmission but you will want to go with what works best for your opinion on shift feel.
alright, yea i dont know if mine is nothciness, its more of a single grind, but ive read a lot about it on different forums and had a shop drive it, and i still dont know if its what other s2ks are like, ive only driven mine
Originally Posted by s2k dre,Sep 6 2010, 03:48 PM
I change mine every 30k but also i drive very easy.
To the OP, I use Honda MTF but it shears down quickly, maybe the oil pump contributes to this. If you go OEM, I'd recommend changing it out at the most 15K.
Originally Posted by Croc,Sep 7 2010, 02:11 PM
7 months and 3000 miles is way too early.
unless you did them all on track.
but if you can't help it - go ahead
Aside from the tranny fluid change, you should adjust the clutch rod & regrease your shifter ( https://www.s2ki.com/forums/index.ph...&f=22&t=772277 )
