Should I test disabling EPS?
Hi, sorry if this has been discussed before.
I did a search and know that by just removing the fuse #33 EPS will be disabled. I really want to get a try
, but I'm afraid of the potential problems afterwards. Also saw from the posts that the EPS reset sometimes works, sometimes doesn't...
So, does anyone can tell me if it's safe to disable EPS for a try and then put the fuse back and everything will work as before
, but I'm afraid of the potential problems afterwards. Also saw from the posts that the EPS reset sometimes works, sometimes doesn't...So, does anyone can tell me if it's safe to disable EPS for a try and then put the fuse back and everything will work as before
Originally posted by gernby
I am curious to know why you want to disable it.
... But I know I need it for daily use, so just want to test if the feeling is good...
