Single click from rear wheel area
About 4.5k miles and 11 months ago, I had an audible single click from the rear wheel area whenever accelerating. It occurred in either forward or reverse directions. It was the rear passenger side only.
I performed the axle nut TSB myself and the click went away. I torqued both sides to ~240 ft-lb, which was about 15-20 deg further CW than the original location. I used mobil 1 synthetic grease on the bottom face of the nut and re-staked the nut afterwards. For what it's worth, the passenger side was relatively easy to take off. On the driver side, I had to get a friends help to remove the nut.
Now, I have a click coming from the same location. It is suspiciously similar. Although I recall that it was previously quieter, and higher pitched. Now it feels more severe and is deeper in tone. It doesn't happen every time I accelerate, so it is intermittent in that way. Also, it doesn't necessarily only happen from a dead stop. I can hear it on the freeway when I significantly change acceleration. It is just a single defining click, which from my readings is still indicative of the axle nut.
I bled the brake fluid to remove the possibility of a sticking caliper. I also got under the car and inspected it closely for bad rubber or loose connections; didn't find anything. I couldn't reproduce the sound by hitting anything with a rubber mallet. Also, the suspension itself is dead-quiet when I bounce up and down on the corner. Finally, I rechecked the torque on both nuts and they both are still at 240 ft-lb or higher.
So now what are my next steps?
I had something similar happening to me. I also did the rear axle TSB, twice. I thought I might have gone too far the first time. It drove me crazy.
However, I discovered that some extra tools and items I had placed on the spare tire were moving and making a clicking sound as they hit the metal spare rim. I wrapped items in Costco micro fiber towels and the problem was solved!
I hope someone can help OP.
Piggybacking on this thread, the rear of my car "ticks" as if I've shut the car off (stationary), and the car is cooling down... Only that the car is on!
I'd stop the car, leave it running, go into the house to get something really quick, and the rear of the car would just tick tick tick tick away.
Any ideas? Thanks!
Any ideas? Thanks!
Any ideas? Thanks!
Any ideas? Thanks!
Only other recent work is not related: new fluids, valve adjustment, and front brakes.
Which parts do I check? The carrier bolts for the caliper? Doesn't the pad just sit within a pocket and is located by the ears? Sorry... this is a good lead for me, but I don't know how the pad itself would be loose.
Literally just check the pads are a sung fit, you can sometimes find that some brands of pads can be a slightly different size, if you are using OEM pads then still check but you can probably discount my theory.
I know this is old but I wanted to close on it, in case it helps anyone else.
I redid the axle nut fix AGAIN, and haven’t had this click in years. I hate to think I did it wrong the first try, but *shrug.
