Snapped vtec pressure switch off
Old Apr 23, 2009 | 03:07 AM
s2konroids's Avatar
Default Snapped vtec pressure switch off
Hi chaps, i serviced the car today.
Whilst finishing up tightening the oil filter i slipped and snapped the vtec oil pressure switch item off.
I managed to glue it back on, and so far it has stayed put. Car has no CEL's and engages in vtec fine.
JDM's S2000's dont have this, i have been told if it does come into use my engine is broke anyways due to oil pressure.
I fear it might come off even though it is securely in place, Can i replace just this item?, or do i have the replace the whole unit?
Circled in yellow. - see the Hex at the end?
Thanks in advance
AJ
Old Apr 23, 2009 | 01:00 PM
jzz30's Avatar
yea you can just buy the sensor its like 60 bucks or something like that not too expensive
Old Apr 23, 2009 | 02:33 PM
Nate4635's Avatar
I did the same thing You are just talking about the connector right?
I snapped the connector off (really just most of the housing) and bend the pins. I straightened out the pins and zip tied the sensor back on until I got a replacement.
Like Jzz30 said, you can get the sensor, but I found the whole vtec solonoid assembly cheaper than that in the marketplace - id search around there if your car runs fine now.
Old Apr 23, 2009 | 04:22 PM
Boofster's Avatar
Old plastic will get brittle and snap off like this.
Just get a new sensor from an online OEM dealer. Should be cheap.
It's hard to prevent this from happening but you can try to keep plastics and rubber wet/conditioned with various liquid products.
Old Apr 23, 2009 | 09:39 PM
itlynstalyn's Avatar
I broke the connector housing off and wrapped in electrical tape. Can you buy the connector by itself? I thought it was hard wired to the harness....
F1TwoThousand
Jul 17, 2018 01:26 AM
Forcedbird
Aug 18, 2016 10:02 PM
bjt1ngle
Sep 29, 2011 03:55 PM
S2ky0118
Oct 11, 2006 05:39 PM
