soft brakes after brake caliper replacement!
Old 08-21-2014, 01:31 PM
ktwenty's Avatar
Default soft brakes after brake caliper replacement!
I replaced my two front calipers as one was sticking, however after following the standard bleeding procedure using those vacuum tools I can't seem to get the brake pedal hard! I'm following the sequence and using grease at the nipples to prevent air from getting in, did the sequence 3 times and still a soft pedal! Very soft! What could be the issue? Vehicle is rhd though
Old 08-21-2014, 01:32 PM
ktwenty's Avatar
Old 08-21-2014, 01:36 PM
fernando.'s Avatar
There is still air in the system.
Let them gravity bleed for a good 30-45min checking the fluid level occasionally. You don't need to put grease on anything.
Old 08-21-2014, 01:47 PM
Site Moderator
Manga_Spawn's Avatar
^What he said. I did have to put grease on the rear bleeder screws. Also make sure the ebrake is off.
Old 08-21-2014, 03:19 PM
slalom44's Avatar
Did you make sure your rear brake piston slots are lined up correctly with the new pads? It's been a while since I did my last brake job but I recall that it has to line up or the pads will be loose.
Old 08-21-2014, 05:35 PM
nissanfanatic's Avatar
I'd try this:
https://www.s2ki.com/s2000/topic/969...t__p__21905941
Old 08-21-2014, 05:50 PM
96-EJ6's Avatar
Get a buddy and bleed them the old school way...all four.
Old 08-21-2014, 06:01 PM
mas2kap1's Avatar
i'm having the same thing!
just replaced my 2 rear calipers!!
bled them too!
but its getting a little bit better..
Old 08-22-2014, 11:32 AM
ktwenty's Avatar
Thanks for the advice will try bleeding with some help then leave the brake depressed over night. Will post results soon.
Old 08-22-2014, 01:05 PM
Site Moderator
Bleed them again. It took several times when I put my Brembo's on to get a firm pedal.
beyondmondays
09-07-2017 07:11 PM
FREEK
03-28-2012 03:40 PM
dan_uk
09-21-2009 08:50 AM
99SH
11-16-2007 06:57 PM
Quick Reply: soft brakes after brake caliper replacement!
