Soft top issue. Needs expert helps
Old May 4, 2013 | 09:02 AM
Ryans2kGPW's Avatar
Default Soft top issue. Needs expert helps
Hi s2ki members,
I'm running into some issues with my soft top. When I press on the roof button it doesn't show any responses, I then unplug the cable under center console and it worked.
Unfortunately, that trick only worked twice and now the soft top completely not showing any response when i press the roof button down.
My only guess what could be the issue is the battery doesn't have enough juice since I'm running an audio system as well (alpine 9887, 4 channel amp, component speakers, and an 8" sub)
The motor worked fine the last time I was able to use the soft top.
Any of you guys ran into the same issue ?
Thanks in advance
Old May 4, 2013 | 09:06 AM
Ryans2kGPW's Avatar
Also I'm running on stock honda battery
Old May 4, 2013 | 01:03 PM
JDMhondaS2K's Avatar
I don't think the battery, make sure you have the parking brake pulled up as this will stop the top from moving.
Sent from my HTC6435LVW using Tapatalk 2
Old May 4, 2013 | 10:51 PM
Ryans2kGPW's Avatar
I have checked, the hand break has always been engaged every time I press the roof button.
Old May 5, 2013 | 03:04 AM
jsenclosure's Avatar
Mybe you need new motors
samson123
Sep 20, 2017 09:15 AM
s2k231
Feb 29, 2016 06:18 AM
Deep Impact Aaron
May 9, 2013 07:22 AM
J_s2
Oct 11, 2010 01:11 PM
JPNSPEC
Sep 20, 2005 12:44 PM
