Solution to eps problems/power steering issues
Old Mar 7, 2012 | 11:15 AM
silverstoneds2k's Avatar
Default Solution to eps problems/power steering issues
Got my power steering fixed guys finally!!!! Do not try to diagnose the problem by replacing parts i repeat do not do it or take to a mechanic other than honda to diagnose they wont be able to without the honda computer thing. My eps system just had to be reset took it to my buddy who works at honda 15 mins later problem solved!!! If you are having problems with eps take it to honda they are the only ones who can diagnose and fix it no 1 else can i repeat no 1 else can. I bet all you guys that are having problems just need to get your eps reset by honda just bite the bullet take to honda that is experienced with s2k. trust me i have been driving with no eps for almost 2 years which pisses me off because it was a easy fix
Old Mar 7, 2012 | 08:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
We with proper knowledge will continue to reset the system ourselves just as the repair manual states. Been there done it.
I assure you Honda has no experience with the s2k. Any clown can plug in a SCAN TOOL with no knowledge of its workings and reset the system. Just go to EPS then RESET.
I assure you the only time you NEED Honda is to write keys.
The rest is s2ki, guaranteed.
Old Mar 7, 2012 | 08:11 PM
Billman250's Avatar
Top Answer: 1
As per the repair manual: To reset the eps, hook up the scanner and follow the prompts.
Anyone who knows how to read and push buttons can apply
Lets not kid each other into thinking you need the dealers "expertise". It doesnt exist.
Knowledge is power.
Old Mar 7, 2012 | 08:14 PM
2003AP1's Avatar
Is there a way to do it without the scanner?
Old Mar 7, 2012 | 08:24 PM
Billman250's Avatar
Top Answer: 1
of course I have it posted in a thread somewhere. Pretty recent too.
Old Mar 9, 2012 | 07:44 AM
I stand corrected only take your car to the dealer if your not mechanically inclined and if your buddy works there who will not charge you. You guys are right simple procedure
ahrmike
Feb 11, 2016 07:03 PM
silverstoneds2k
Mar 7, 2012 11:42 AM
trendy26
Feb 23, 2006 02:29 PM
marcucci
Apr 24, 2002 04:25 PM
andrewewing
Jan 23, 2001 11:39 AM
