some weird clutch issues
Old Mar 13, 2013 | 09:44 PM
s2pat's Avatar
Default some weird clutch issues
Alright, so last friday id say my clutch started acting funny. When switching gears i felt as if the clutch pedal was coming back out to fast or felt is if it extended further back (towards the rear of the car) when released. Also for the most part, when pressed in, the clutch pedal, if not coming back, it would stay pressed to the firewall but i would be in gear. I was told different solutions to the problem. Someone told me it was the master cylinder. I said it couldn't be because it was just changed maybe 3 months ago. Someone said it was the slave. So i changed it, and after driving the car tonight i did notice, the pedal was not sticking to firewall anymore. The pedal like i stated earlier, seemed to come back faster or extend further. Another person said it could be the rod from the master to the pedal. Anyone ever experience this issue?
s2pat's Avatar
also my clutch was sliiping really bad on the test run tonight.
Old Mar 14, 2013 | 05:33 AM
drobinson1692's Avatar
After you did the slave, did you bleed the entire system? Do the gravity method. Also you need to adjust the rod from the cylinder.
StrokerSi
Aug 10, 2017 06:26 AM
03S2
Feb 20, 2011 02:17 PM
LubedKoala
Feb 7, 2009 04:09 PM
rikhemi
Sep 10, 2007 06:29 PM
Big_Al
Nov 11, 2005 11:45 AM
