Spal fan install help
Old Jan 25, 2016 | 08:16 PM
  #31
chefs2000's Avatar
This was under the diagram I posted
[attachment=90227::]
Old Jan 25, 2016 | 08:26 PM
  #32
99SH's Avatar
Won't blow anything, it'll either work or it wont.
That diagram underneath was what I was referring to all along for the 2nd relay
Old Jan 25, 2016 | 09:33 PM
  #33
chefs2000's Avatar
I thought AA and BB were relays .. I guess I don't know what a relay is lol .. Thanks for u wealth of knowledge in the subject .. I owe u one ...
Old Jan 26, 2016 | 05:17 AM
  #34
99SH's Avatar
AA & BB are just reference call-outs in the drawing used to specify the cable length.
SPAL just emailed back and wrote:
I have never tested the relay on these kits to reverse the wires so technically you might be correct and I am not sure if there is a diode in this relay. The question I must ask is why does it matter? You can ground the gray wire and trigger the orange wire with a positive trigger if that is what you are trying to do. Please provide us with more details on how you want to wire the fans.
If my first diagram above does not work that means they have a diode in the relay. If so, you need to swap the Orange and Wires (so Orange to Blue/Black on OEM harness and Gray to chassis/gnd)
Old Jan 26, 2016 | 05:36 AM
  #35
chefs2000's Avatar
Originally Posted by 99SH
AA & BB are just reference call-outs in the drawing used to specify the cable length. SPAL just emailed back and wrote: If my first diagram above does not work that means they have a diode in the relay. If so, you need to swap the Orange and Wires (so Orange to Blue/Black on OEM harness and Gray to chassis/gnd)
Ok thanks a lot I'll give this a shot . First by grounding the orange wire .. If not I'll reverse the grey and orange wires .. I'll post up as soon as I know .. Thanks again brother
Old Jan 26, 2016 | 09:18 AM
  #36
chefs2000's Avatar
Ok just hooked the orange wire to battery negative and no fan when I click ac on.. Now I will try to ground the grey wire and connect the orange to the fan switch wire blue and black
Old Jan 26, 2016 | 09:21 AM
  #37
99SH's Avatar
Make sure you have the black & red wires connected to the chassis and battery (+), respectively. In your earlier post you had mentioned a black wire was not connected somewhere.
Old Jan 26, 2016 | 10:11 AM
  #38
chefs2000's Avatar
I just switched the wires and still nothing when ac is turned on
[attachment=90256::]
Does the wiring look right ?
Should I just run the relay ? Or maybe it's something else
Old Jan 26, 2016 | 10:12 AM
  #39
chefs2000's Avatar
I have the negatives grounded to the neg terminal .. The only open wire is the ground wire that comes off the oem connector
Old Jan 26, 2016 | 10:23 AM
  #40
99SH's Avatar
Something may not making contact.
Try to verify the functionality of the relay. Connect the Orange wire to +12V Battery and Gray wire to Battery Negative. Does the big SPAL relay click? If not, flip Orange to negative and Gray to +12V, does it click?
