Spal fan install help
Old Jan 26, 2016 | 11:48 AM
  #51
chefs2000's Avatar
Originally Posted by 99SH
The fans are already connected together in the stock configuration. If the AC is on OR if the temperature reaches 199F both fans turn on. You cannot have one fan on without the other. edit: If you have a volt meter, verify that +12V is on the Blue/Black wire when the AC is on. If voltage is not present, the OEM FAN relay is bad.
Do both oem fans have Seperate relays ? So if passenger side is broke then the blue and yellow should still work ?
Old Jan 26, 2016 | 12:02 PM
  #52
chefs2000's Avatar
Also when I put ac on the driver side fan don't go on
Old Jan 26, 2016 | 12:07 PM
  #53
chefs2000's Avatar
Also oem relay is in the fuse box correct ? Can I switch it with one of the relays above or below it ?
Old Jan 26, 2016 | 01:41 PM
  #54
99SH's Avatar
Yes, two separate fuses for each fan. They are located in the under-hood fuse box. I haven't looked whether they are interchangeable.
Old Jan 26, 2016 | 02:06 PM
  #55
chefs2000's Avatar
Ok .. I switched the fan relays and no luck .. I tested both the blue and yellow and blue and black with the tester with ac on and no light ... I am now letting it go up to temp and see if the driver side fan comes on and I'll chek the wire for power then and also the passenger side
Old Jan 26, 2016 | 02:15 PM
  #56
chefs2000's Avatar
Ok ... When car is up to temp the fans both come on and I get light from the meter on both ends .. So why don't the passenger fan come on with ac on ? Is that a issue ?
Old Jan 26, 2016 | 02:33 PM
  #57
99SH's Avatar
Good there's progress.
Did you mean to say why don't passenger and driver fans come on with AC on? - They should BOTH turn on with the AC
Edit: Check the 20A fuse on the AC fan, make sure it's not blown.
Old Jan 26, 2016 | 02:36 PM
  #58
chefs2000's Avatar
Ohh I thought only passenger would come on... maybe it has to be up to temp first ... Or if I turn the car on cold and put ac on, should fans come on ?
Old Jan 26, 2016 | 02:50 PM
  #59
99SH's Avatar
When the AC is turned on (make sure AC button is lit), it bypasses the Temp switch. It doesn't matter if the coolant is up to temp; as long as AC is on the fans should be ON.
Old Jan 26, 2016 | 02:57 PM
  #60
chefs2000's Avatar
Ok so fuse is good
