Spark Plug change DIY
Old Sep 30, 2010 | 05:25 AM
  #71
w00t692's Avatar
Very useful. I recently changed mine but no hardware stores had denso OR NGK. I had to use bosch, which seem to work fine, my gas mileage went up, power feels unchanged, idle is smooth.
Reason for change was not mileage but was age. The plugs in there were 10 years old (literally)
And for what it's worth, for 10 years old they looked pretty damn good. Also came out of the engine without fuss.
Old Sep 30, 2010 | 09:35 AM
  #72
SlowTeg's Avatar
For a tip on changing plugs.. You don't need to use electrical tape for the extension and socket. If you merely put some lateral pressure on the extension it'll keep the socket from popping off the extension when pulling up. It needs to be done in a specific direction (because of the spring ball on the extension), so if it pops off the first time, just try again.
Old Dec 9, 2010 | 02:42 AM
  #73
dotti1190's Avatar
Originally Posted by Saki GT,Feb 19 2010, 04:25 PM
Copper and Gold are good conductors but they require more frequent cleaning and replacing. Good if you are FI, prob not the best choice if you want a reliable low maint plug.
definitly cheap copper plugs are the way to go if it doesnt bother you to change your plugs every year (whats 30 minutes a year) copper have proven time again to provide more spark then platinum or iridium
Old Dec 9, 2010 | 09:41 AM
  #74
rrounds's Avatar
I'm sorry but that's not a true statement.
The smaller the center electrode, the hotter the spark will be with the same volts.
ROD
Old Jan 24, 2011 | 12:36 PM
  #75
chuhsi's Avatar
on my maintenance todo list. thanks!!
Old May 5, 2011 | 09:43 PM
  #76
S2k007's Avatar
Just want to make sure this is the correct spark plug everyone is using before I order.
http://www.amazon.com/NGK-PFR7G-11S-Laser-Platinum-Spark/dp/B000HWK74K/ref=au_pf_pfg_s?ie=UTF8&Model=S2000|760&n=15684181 &s=automotive&Make=Honda|59&Year=2000|2000&newCar= 1&carId=001
Old May 6, 2011 | 06:11 AM
  #77
INDYMAC's Avatar
That is the plug I replaced mine with in a 2004 F22. I noticed that Handa-accessories has a plug for sale that has the "Honda" brand on it. Is that an NGK plug too?
http://www.handa-accessories.com/s2000-04maint.html
Old May 6, 2011 | 05:56 PM
  #78
zeroptzero's Avatar
That is just the NGK oem plug shipped in a Honda box, and then the dealer can charge a different price that way.
Old May 16, 2011 | 07:47 AM
  #79
FISH22's Avatar
Plan on doing this sometime this week. Great write-up!
Old May 16, 2011 | 01:02 PM
  #80
FISH22's Avatar
Well, checked with 3 Autozones and 2 Pepboys, and none of them have these in stock. Guess I'll be ordering them.
