spark plug coil pack wire harness clip
Old Apr 2, 2009 | 07:41 AM
klee1113's Avatar
Default spark plug coil pack wire harness clip
can the clips be replaced?
Old Apr 2, 2009 | 03:00 PM
klee1113's Avatar
bump
Old Apr 2, 2009 | 03:24 PM
Slows2k's Avatar
There isn't a coil wire, are you taking about the connectors that attach to the individual coils?
They can be replaced if you cut them from another harness.
Old Apr 2, 2009 | 06:50 PM
klee1113's Avatar
right the connectors. how would u replace them? do u have to splice the wires? or can the plug be pulled apart?
Old Apr 2, 2009 | 10:16 PM
SgtB's Avatar
Did it completely shatter, or did you just break the lock off? It's ghetto, but a tywrap would hold it on just fine if it's just the lock.
Old Apr 2, 2009 | 10:56 PM
PWRMKR's Avatar
most of time you can, with a small tool, unclip, and pull the wire terminals out of a busted connector. I would think you can with coil connector.
check the local recycle yard for a good connector and just remove the terminal and plug yours in.
gl
Old Apr 3, 2009 | 07:24 AM
klee1113's Avatar
just the locking clip.. POS piece of plastic
Old Apr 3, 2009 | 07:29 AM
klee1113's Avatar
llike zip tie?
Old Apr 3, 2009 | 06:50 PM
SgtB's Avatar
Yes. Run it between two wires on the connector and around the pack. Just make sure it's in a way that wont allow it to vibrate off. You can also extract the pins and snap them back into an old connector like PWRMKR said. You may be able to use the larger radioshack tool, but I'm not sure how weatherpacks clip, off the top of my head.
mongomery1234
Dec 13, 2019 10:31 PM
mroverkill
Sep 16, 2015 04:04 PM
ayau
Jul 3, 2010 09:37 PM
chrisesteban
Dec 13, 2009 08:50 AM
