speedometer stopped working, EPS light on
Old Mar 22, 2011 | 06:09 PM
JPRICE!'s Avatar
Default speedometer stopped working, EPS light on
AHH so i stopped at a gas station and filled the car up and when i left i noticed my speedo stopped working then shortly after the EPS light came on. Anybody have a clue to what is going on?
Old Mar 22, 2011 | 08:21 PM
Stratocaster's Avatar
The speed sensor is tied the the EPS computer. So do you have gear and a speedo adjuster?
Old Mar 23, 2011 | 06:12 AM
JPRICE!'s Avatar
ive got 4.77's and a yellojacket calibrator
Old Mar 23, 2011 | 06:18 AM
Check the connections for the yellow jacket. Odds are they are loose or disconnected. If that fails uninstall the yellow jacket to see if it went bad.
Old Mar 24, 2011 | 02:30 PM
raymo19's Avatar
New search must not suck all that bad. It led me here. Picked up my car today after a clutch change and had the same symptoms. My yellow box is under the console and the connector must have worked loose when the shifter was put back in. I snugged it back up and we're all good now.
In my case the EPS light was intermittant and the strangest part was when I stopped the car at idle I could pull the steering wheel left to right once and let go and it would move the same range left to right by itself until I stopped it. Freaky.
Old Mar 24, 2011 | 04:11 PM
ronnuke's Avatar
This very thing happened to me a while back and my yellowjacket had failed giving the symptoms you describe. Installed a new yellowbox and it has been fine since.
Old Mar 25, 2011 | 03:24 AM
JPRICE!'s Avatar
loose negative battery terminal
Old Mar 25, 2011 | 04:09 AM
raymo19's Avatar
That's really strange. Glad you got it sorted.
mikefifth
Oct 21, 2014 02:55 PM
Leadhead16
Apr 21, 2010 06:05 AM
Lttakas
Aug 30, 2009 12:55 AM
goldenfri
Oct 15, 2007 01:31 PM
news2kroller
Nov 14, 2006 04:40 PM
