spoon strut bar
Old Jan 10, 2007 | 05:16 PM
gt489's Avatar
Default spoon strut bar
i just bought a spoon strut bar and i have an aem cold air when the strut bar is installed the touch i havent started it yet but by the looks of things the toque ill push on the intake and strut bar should i crease the intake?? thanx for ant help
Old Jan 10, 2007 | 05:37 PM
SenderGreen's Avatar
Dude, What?!
"i just bought a spoon strut bar and i have an aem cold air"
That's almost a sentence, and the only part I could figure out.
You have a Spoon STB and something from AEM.
I had an AEM cold air intake on a CRX. You don't want the powdercoated AEM intake tube to rub on anything. I've read horror stories on the CRX forums of an intake tube rubbing a small nickel sized hole in itself. Once there is a hole little bits of crap including the intake tube itself are sucked into the head.
Wedge some EPT foam or whatever it's called in there.
Old Jan 11, 2007 | 06:34 AM
vtec9's Avatar
Originally Posted by SenderGreen,Jan 10 2007, 09:37 PM
Dude, What?!
Old Jan 11, 2007 | 07:36 AM
Shadow_S2K's Avatar
Former Sponsor
The Spoon Strut bar will rub when installed with the AEM intake. Its best to put soemthing inbetween to avoid direct contact.
Old Jan 11, 2007 | 07:47 AM
DreamS02K's Avatar
I have the exact same setup. AEM Intake with the Spoon STB. Mine did rub when first installed. The most damage that it made on my car was it scratched the paint away on the intake. No creases, rattles, noises etc... I just stuck a small stick on 1/8" thick foam pad on the bottom of the Spoon brace and it was fine after. No more paint being rubbed away.
Old Jan 11, 2007 | 11:06 AM
S2KPUDDYDAD's Avatar
You can make Strut tower Spacers This will help to clear the CAI you have.
Old Jan 11, 2007 | 09:12 PM
blackout's Avatar
or you could attach a small piece of weather stripping to the bottom of the strut bar to avoid metal on metal contact. That shouldnt be too visible either. The spacer idea may work, but then you could run into problems closing the hood, or premature failure of the strut bar.
Old Jan 12, 2007 | 06:35 PM
gt489's Avatar
thanx for the help
lreyn003
Jan 13, 2010 07:14 PM
RAYZ-Ace
Jul 28, 2009 04:09 PM
thatguyjosh
Sep 11, 2004 02:30 PM
OverBooster
Mar 23, 2004 08:41 AM
OverBooster
Jan 29, 2004 06:10 PM
