squeaking noise when decellerating from the rear
Old Mar 11, 2008 | 03:40 PM
ABCVTEC's Avatar
Default squeaking noise when decellerating from the rear
so im hearing a squeaking/grinding/squeeling noise coming from the driver side rear of my car. its sounds exactly like when my weel bearing went out a couple months ago and its definitely on the driver side again.
two months ago i had my wheel bearing replaced. i bought the bearing from honda directly and had a mechanic do the install. do you think this could be my wheel bearing again or something else? possibly i need to retorque my axle nut? im just hoping i dont need to replace the bearing again already. i only hear the sound when i am decellerating or slowly accelerating from 0 to 30.
any help is appreciated. ive already called honda and they pointed the finger at my mechanic saying it was a bad install. then i called my mechanic and he pointed the finger at honda saying it was a bad wheel bearing. go figure.
any help is greatly appreciated.
(sorry for the lack of grammar as i made this post from my phone.)
Old Mar 11, 2008 | 08:37 PM
SIIK2NR's Avatar
Did you check your brake pads and rotors?
Old Mar 11, 2008 | 11:24 PM
ABCVTEC's Avatar
Pads and rotors are fine. The sound doesn't stop when I start braking.
Old Mar 12, 2008 | 12:59 AM
SIIK2NR's Avatar
Did your mechanic give you or show you the old bearings?
Old Mar 12, 2008 | 09:07 AM
ABCVTEC's Avatar
No he did not
Old Mar 12, 2008 | 09:28 AM
jyeung528's Avatar
did you replace the hub?
perhaps the hub was damaged by the old bearing...which damaged the new bearing quickly...
Old Mar 12, 2008 | 10:12 AM
Spa_Ap1's Avatar
Old Mar 12, 2008 | 10:14 AM
ABCVTEC's Avatar
I have a feeling that is a possibility as well. Even though I don't like to think it. I'm going to have my brakes done tomorrow. New pads, rotors resurfaced. If that doesn't do it, I'm ordering a new hub and bearing and having Honda do in the install so I don't get stuck in this finger pointing BS again :[
WarrenW
Oct 28, 2017 08:21 AM
s2kev
25
Jul 11, 2011 02:28 PM
ryanswhites2k
Apr 15, 2011 06:03 PM
boosted_ap1
Apr 18, 2008 05:58 AM
suzukawoods
Jan 11, 2006 09:18 AM
