SRS belts
Old Jun 22, 2008 | 03:06 PM
wazzurp's Avatar
Default SRS belts
I have one side of my seatbelts lock up and it is real close to the end and it wont release any more of the belt. Is there anyway to unlock these damn things. Ive tried to hook it back up and reset battery and then turn car on, off, etc..
Any suggestions.
Old Jun 27, 2008 | 10:10 AM
Kirpich's Avatar
It depends on the reason it locked up. Aibag (SRS) light on? I've had to replace mine, and it's doable, but need to reset the airbag code later on, which wasn't hard to do at all.
I took mine apart, and it has a 12V-activated Shell, like a gun or shotgun shell that expodes and locks them up. So no way to unlock it if the SRS system set it off for some reason. If it's mechanical, just carefully take the plastics off, see if there's an obstruction of some kind.
Mark K.
Old Jun 27, 2008 | 03:38 PM
RISLAR's Avatar
Mark K.
its a repacement if its locked!
Old Jun 28, 2008 | 07:23 PM
khiz's Avatar
on the seat belt where it all goes in to, if you take the clear plastic cap off... you can pull out the belt, but the seat bely assembly has to be sittin up straight.
once pulled out have someone hold it and put the plastic cap back on and screw it back into your car or else it will lock again.
i dont want to be responsible if anything happens, this is just how i did mine when they locked.
Mintyhit
Oct 5, 2022 07:59 PM
HS2K007
Jan 23, 2013 06:29 PM
deepbluejh
Feb 16, 2012 11:47 AM
kchandra
Jul 26, 2009 04:22 AM
negcamber
Jan 29, 2007 08:04 AM
