SS clutch line install question
Old Feb 14, 2010 | 12:42 PM
rspenc's Avatar
Default SS clutch line install question
I'm in the process of replacing my clutch master and slave cylinders. I picked up a stainless steel clutch line at the same time. The stainless line's banjo connector doesn't have the pin tab that prevents rotation like the OEM line. Is this a problem? The pin can be seen in the second picture in this post. https://www.s2ki.com/forums/index.php?showtopic=370792.
Has anyone used a clutch line without the pin/tab? I'm just concerned about it rotating, loosening and then leaking.
Old Feb 15, 2010 | 12:55 AM
rspenc's Avatar
Any help? I just want to hear from someone who has used a similar line. All the after market lines, I can find a picture of, do not have the pin.
Old Feb 15, 2010 | 04:05 AM
fl_speed001's Avatar
I have not installed stainless lines on the S2000 yet, but I have installed them on other cars and I encountered the same thing. You should be fine, make sure to use the copper washers on the banjo bolt and tighten to spec and you should be good.
Old Feb 15, 2010 | 05:13 AM
SilverS2kF22C1's Avatar
Yup that's all you really need to do. You may have to hold the line in place as you tighten it up because it will want to rotate. out of position, the main reason it has the ear to start!
Old Feb 15, 2010 | 05:29 AM
rspenc's Avatar
Thanks, That's what I thought. Just wanted to confirm with someone to avoid a tow charge.
Mr.SweetRoll
Jun 18, 2013 10:14 PM
Calamari
Mar 24, 2011 08:53 AM
splatter85
Apr 19, 2010 09:41 AM
cbrguy7
Dec 21, 2007 01:24 PM
dbzerk
Dec 11, 2006 04:26 AM
