Starter motor?
took the car for the geo to be done, go out and test the car and all fine. Go to start up the car to come home and zilch!
key in ignition, all the lights on as usual, press the button and not even a little sound! No sound at all.
Could it be the starter motor thats gone or something else? Have a Mugen ecu so that disables the immobiliser I believe.
If your not hearing ANYTHING from the starter at all my guess would be something wrong with the engine start button. Possibly a fuse or relay not to certain but if your hearing a clicking noise from the starter its probably the starter solenoid. I'd go ahead and replace the whole starter if your going to do the solenoid though since its attached to it and getting the starter out of our car isn't very easy.
Originally Posted by s2000 gib,Oct 3 2010, 06:21 AM
thanks crank, do you know if you can just have it rebuilt or is it cheaper to buy the whole thing?
If there is no noise when you try to start your car, then the starter is bad. If you hear clicking, then the starter contacts are going bad. I would replace the whole thing if you have to go in there for either scenario.
