Starter motor replacement
Old Nov 24, 2007 | 09:54 AM
DaveA's Avatar
Default Starter motor replacement
OK, has anyone replaced the starter motor on a left hand drive 2000 S2000?
I just spent the better part of three hours following the manual and removing the belt, tensioner, alternator and the intake tray and there I am. The next step in the manual is to remove the starter. There is no way I can get to any part of the starter as things set now. I can't even see the starter from above. On the lift I can see a piece of the solenoid and the bottom bolt but there is no way it's going to come down from above.
I'm beginning to think the manual applies to a right hand drive car only.
There has to be a trick in here! Anyone know the rate that Honda charges to replace a starter!
Thanks for any tips.
DAve
Old Nov 24, 2007 | 10:04 AM
NVMY4N's Avatar
Check the FAQ/DIY there is a write up there. It may help
Old Nov 25, 2007 | 05:09 AM
DaveA's Avatar
Thanks for the tip about the FAQ. I could swear that I looked around and didn't find anything before I started this.
Well, I read the FAQ and looked at the car and anyone who got that starter out from below must work as the rubber jointed man in the circus. I guess I give it another go later on in the week.
Thanks again.
Old Nov 25, 2007 | 08:04 AM
airgate's Avatar
I just had my starter replaced...car sounds _NEW_ at start up now! I had that God-forsaken "GRIND" noise at start up...uck!! Now it's gone!!
Old Nov 25, 2007 | 10:15 AM
Slows2k's Avatar
You need a long socket extension and flex sockets to reach the bolts.
mikey_w50
May 9, 2014 01:18 PM
whitegv
Sep 19, 2012 04:25 PM
superjiff
Mar 8, 2010 05:45 AM
s2konroids
Feb 9, 2009 10:05 AM
