steering problem
Old Jan 12, 2005 | 10:01 PM
farmer's Avatar
Default steering problem
ok here is the story.
when making a right turn at an intersection, i span out and crushed on the curb.
the car actually went on the curb and came down.
the passenger front wheel hit the curb first.
after that, the car was lean towards right and the steering wheel was off towards right also.
then, i took my car to the alignment shop. they told me i need to change the lower control arm. that should fix the problem.
but now when i make a right turn, the car doesn't respond as fast as before.
and sometimes when i turn the steering wheel 30 degree to the right, the car still giong straight. then it slowing turns to the right.
what might be the problem here?
is there anything i can do to fix it?
Old Jan 13, 2005 | 07:36 AM
xviper's Avatar
Do they change to ball joint when they change the control arm? It just sounds like a bad ball joint but if it was changed, then ................
shamusodoofus
Mar 12, 2011 10:25 AM
PHAMS2K
Nov 21, 2010 06:20 PM
Thanhstar
Aug 3, 2009 09:06 AM
nexus
Jun 9, 2007 03:44 AM
S9735
Oct 10, 2005 04:14 PM
