Steering torque sensor removal
Old Mar 6, 2021 | 02:59 PM
S2K_FD3S's Avatar
Default Steering torque sensor removal
Hi all
I have a 2k2 that's having the dreaded steering vibration and pulls the to the right on cold starts. I read that I should try cleaning and regreasing the steering torque sensor. I got it loose but can't get it completely out. What am I doing wrong? Any tips or tricks to get it out? Pic below
Old Mar 6, 2021 | 04:58 PM
cosmomiller's Avatar
Top Answer: 1
A number of threads on just this. Cleaning will solve the problem. There are some good does and don'ts.
Good luck!
Old Mar 7, 2021 | 02:44 AM
Slowcrash_101's Avatar
You loosen both bolts on the steering coupler?
Also if your t25 doesn't work on the security bolts you can use vice grip pliers.
I made a thread called "torque sensor guts" it shows you the slip ring aka beige piece, that has to move smoothly. Use a polyurea grease since it's compatible with plastics and metals.
Old Mar 7, 2021 | 10:25 AM
S2K_FD3S's Avatar
You talking about these 2 right? I took them out already. Been trying to wiggle it out but no dice.
I made a thread called "torque sensor guts" it shows you the slip ring aka beige piece, that has to move smoothly. Use a polyurea grease since it's compatible with plastics and metals.[/QUOTE]
Old Mar 7, 2021 | 01:53 PM
Billman says the rack spring can cause it to bind when trying to install it. Perhaps it does it when you try to remove it as well?
Put light pressure under the driver side tie rod with a jack. Right where the 19mm lock nut is.
Modifry Products
Apr 27, 2017 02:38 AM
JMP136
Apr 21, 2017 05:46 AM
La Ray
Feb 19, 2017 01:21 PM
Ruble03
Feb 7, 2017 08:16 PM
