Sticker remove
Old Mar 27, 2014 | 02:24 AM
switchmorgan's Avatar
Default Sticker remove
This doesn't look good to me . What's the best way to remove this sticker ?
Thanks in advance
Sent from my iPhone using Tapatalk
Old Mar 27, 2014 | 02:39 AM
redlineracing's Avatar
Try a hand held blow dryer first....if that doesn't work,buy some "Goof off".It will remove the decal & the sticky residue underneath.
\rlr
Carolina
Old Mar 27, 2014 | 02:57 AM
kgf3076's Avatar
WD40 will work as well.
Old Mar 27, 2014 | 03:42 AM
I was going to try boiling water then something like goof off ?
Old Mar 27, 2014 | 06:51 AM
cosmomiller's Avatar
Top Answer: 1
\rlr
Carolina
This is the best start. If you have a regular heat gun (for heat shrink wrap, tubing or coverings) that is the better way to go but a hairdryer is a good backup. The decal has a coating of mylar or PVC on top of the adhesive so an application of chemicals (goof off-WD-40) won't work at this point. Heat the thing up so its nice and warm, you may have to CAREFULLY lift an edge using something sharp and as you slowly pull up, apply heat. If there is any residue, now is the time to use goof off or Nature's Orange or something stronger.
Old Mar 27, 2014 | 08:14 AM
Stratocaster's Avatar
http://www.oreillyauto.com/site/c/de...ticker+remover
Old Mar 27, 2014 | 08:41 AM
DrakeValle's Avatar
I'm spoiled and get to use product from my dads shop.
RM-900 works amazingly. Used it to remove the adhesive/residue that was left when I removed door handle protector films.
It's expensive, but it works great for cleaning off residue and other junk, like road tar.
Old Mar 27, 2014 | 05:48 PM
Utah S2K's Avatar
Originally Posted by Stratocaster
X2
Utah
Old Mar 27, 2014 | 07:02 PM
_brandon's Avatar
Beltsander?
Heatgun and goof off were my first thoughts but someone beat me to it..
bkowa092
Mar 18, 2011 07:44 PM
watchdogd
Nov 3, 2009 05:26 AM
SimbaDogg
Apr 1, 2008 06:27 AM
B.Money
Sep 26, 2007 10:53 PM
ragamuffin
Sep 14, 2006 10:59 AM
