Stock Engine Mount Spacing
Old Aug 29, 2018 | 01:56 AM
Jwilly571's Avatar
Default Stock Engine Mount Spacing
Hey everyone, longtime lurker new to the forums. Does anyone know, or have their engine out of an AP1 and able to measure, the distance between the stock engine mounts? Thanks
Old Aug 29, 2018 | 03:47 AM
Slowcrash_101's Avatar
Why take the engine out to measure that? You could just measure the distance of the mount studs as theyre bolted to the subframe.
Old Aug 29, 2018 | 03:53 AM
Jwilly571's Avatar
I just have the engine. Building a frame. Stud bolt distances for the mounts would be pefect as well though. Thanks
Old Aug 29, 2018 | 06:35 AM
Jwilly571's Avatar
Across the subframe pls. Using stock mounts and making brackets. They will eventually be upgraded but want to eliminate some trial and error. Thanks
Old Aug 30, 2018 | 05:18 AM
Jwilly571's Avatar
Bump. Looking for the distance between engine mount bolts on AP1 subframe pls.
Old Aug 31, 2018 | 05:18 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The subframe holes are not only doubled, they are angled. You need to be very specific on what you need, I can get it.
Old Aug 31, 2018 | 05:24 AM
Jwilly571's Avatar
Just across. Back hole across to back hole and front across to front. If you want to do diagonal as well that would work but I believe they are at 45 degrees. Thanks a bunch
shind3
Jan 23, 2015 05:21 AM
mikefifth
Jul 9, 2014 08:26 AM
rikhemi
Dec 25, 2012 06:18 AM
Spoolin
Oct 26, 2006 10:34 AM
