Strange Rattle/Vibration
Old Dec 4, 2022 | 03:01 AM
jZico's Avatar
Default Strange Rattle/Vibration
Hi,
I've recently developed a rattle/vibration after replacing the front upper right control arm, motor mounts (oem), and installing a new Remark exhaust.
-The car rattles and vibrates at idle. Pushing the clutch in and out has no effect. Really noticeable in the cabin and can't really hear it outside.
-The rattling is really apparent when driving.
-I can feel a slight vibration on the pedals when driving. I don't feel vibrations when pushing the pedals at idle.
Weird thing is that the rattle/vibrations popped up soon after replacing the parts, but went away after a week. I drove around fine with no rattle/vibrations for a month then it just recently came back. What could it be? I've noticed that in the driving video, the noise started getting quieter when I went up in gears.
Old Dec 4, 2022 | 04:37 AM
Slowcrash_101's Avatar
Did you replace both mounts? Was an impact gun used to install them? What about other mounts, like differential and transmission mounts? Exhaust hitting on anything?
Old Dec 4, 2022 | 05:24 PM
jZico's Avatar
Yes, both mounts were replaced using the gun. I'm currently on Innovative differential mounts that has been on for a year and a half. Transmission mounts have not been swapped out yet. I don't know if exhaust is hitting anything so I'll double check on that. Should I get new transmission mounts for peace of mind?
Old Dec 6, 2022 | 02:56 AM
Using an impact gun to install the engine mounts can damage them.
Old Dec 6, 2022 | 12:51 PM
jZico's Avatar
Ah dam, I'll double check on those too... thanks for the help!
Old Dec 6, 2022 | 02:32 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have used an impact gun on the motor mounts. Every time.
The two botton studs are mounted in a common steel plate. The top plate is keyed to the aluminum bracket through the motor mount center plate. Thee is no risk of twisting or damaging the motor mounts, at least not on the S2000.
tohlenforst
Sep 24, 2018 07:36 PM
bigbombula
Jan 3, 2012 05:55 PM
skyler2k
May 30, 2010 05:29 PM
Jack_in_the_Box
Nov 7, 2009 02:24 PM
Crackerballer
Jun 8, 2009 02:32 PM
