Stuck in second gear.
Old Mar 4, 2016 | 11:23 AM
lowS2k's Avatar
Default Stuck in second gear.
I have an 03 s2000 with 48k and the clutch was replaced 3k ago. The car was driving fine with no shifting issues, smooth as butter. I got home parked the car and I left in second gear with the e brake up and when I got back into it the next mourning to go to work I could not get it out of second gear. What would cause this? What should I look for?
Old Mar 4, 2016 | 11:49 AM
Car Analogy's Avatar
Clutch is not fully disengaging. Hydraulic issue, MC or slave, or something mechanical that prevents the clutch fork not being pressed.
Sent from my SM-G920P using IB AutoGroup
Old Mar 4, 2016 | 12:00 PM
s2000Junky's Avatar
More times then not, even without using the clutch you can row through the gears when the engine is off, especially taking out of gear. That alone makes me think its not hydraulic related. But go ahead and double check that your master is full of fluid and no signs of weeping. Typically when a master goes it will get wet under the clutch pedal on carpet. If slave cylinder leaking, that would be under the car.
I would take off the E brake, push in the clutch and try starting the engine with it in gear and see if it releases once you unload the car from its current position. If your in a neighborhood or something where you can drive the car, do this and see if you can get it operating again.
Old Mar 4, 2016 | 12:49 PM
windhund116's Avatar
"I would take off the E brake, push in the clutch and try starting the engine with it in gear and see if it releases once you unload the car from its current position. If your in a neighborhood or something where you can drive the car, do this and see if you can get it operating again."
This will most likely work.
Or you can try releasing emergency brakes & simply rocking the car. You may have parked on an incline. Gravity is adding force up against the gears in the tranny. Keeping you from going into neutral. Be careful, if it's a steep incline --- as you do not want the car to run over your feet. Or worse.
Old Mar 4, 2016 | 04:00 PM
lowS2k's Avatar
Thanks for the tips. I'm gonna give them a try tomorrow. I will be back with an update.
Old Mar 6, 2016 | 05:38 AM
lowS2k's Avatar
Alright, let the car get a little warm and as soon and I moved the car a few feet it popped right out effortlessly.
pwr2al4
Jul 14, 2015 09:21 PM
Rio Sunset
Mar 6, 2015 03:21 PM
stwoki
Feb 24, 2011 07:15 AM
jstar
Dec 20, 2006 11:58 AM
s2kpr01
Aug 12, 2006 12:54 PM
