Stupid SC question
Old Sep 29, 2004 | 06:29 AM
kyo's Avatar
kyo
Default Stupid SC question
If i get a Comptech supercharger do i need to get it tuned? And if so what else do i need to tune it that does not come with th SC kit?
Old Sep 29, 2004 | 07:34 AM
AusS2000's Avatar
You can either buy it and install it as per the instructions and trust that it is running safely (and that's fairly safe) or install some management and get it tuned properly.
I'd recommend minimum of an E-manage and if you can spare the cash, an AEM EMS.
Old Sep 29, 2004 | 10:20 AM
kyo's Avatar
kyo
What about an Apexi V-AFC? Are do recomend the other two over this?
Old Sep 29, 2004 | 10:30 AM
Sideways's Avatar
The V-AFC is very limited. The AEM EMS is the way to go IMHO. I've been running one for the last 8 months and it does allow greater power to be developed safely. It allows you to change injectors, move timing, customize the knock sensors, even set up traction control.
Old Sep 29, 2004 | 10:44 AM
SEVNT4's Avatar
I rode in Sideways car recently and from what I could tell, it ran like a champ. Very smooth. His car is also not your typical SC application. He's had more work done so it was impressive to see it run so nicely.
Old Sep 29, 2004 | 02:45 PM
AusS2000's Avatar
V-AFC is a toy. It's only A/F control is by adjusting the MAP sensor and as this is already maxed and clamped it doesn't make much sense.
The E-manage can drive injectors directly and control ignition. That's a good start. But the AEM is the ducks guts.
Old Sep 29, 2004 | 04:13 PM
Nobody's Avatar
Keep in mind, Kyo, that all you really need to do after the SC is installed is take your car to a place that does dyno tuning. They'll look at your A/F ratios and adjust the Comptech fuel pressure regulator to keep you in the safe range.
I'm going the EMS route now (after a year or so of happily supercharged miles). If I had to buy the SC, Aftercooler, EMS and Injectors + Tuning all at the same time I would have probably been scared off from the price (I also did ACT clutch, Comptech Flywheel and reinforced diff.).
If you're going to run an aftermarket exhaust and header, though, you NEED to get an AEM EMS as the FPR can't pump enough fuel to keep your ratios right.
RJPhillips19
Jan 11, 2006 09:15 AM
T S2K H
May 11, 2004 01:04 AM
frans2k
Mar 27, 2004 07:29 AM
Money2536
Jun 29, 2003 07:26 PM
brandonb
Dec 24, 2001 01:39 PM
