Suspension problem
Old Oct 11, 2007 | 04:15 PM
milhouse1210's Avatar
Default Suspension problem
Hey guys i just bought myself a 01 S2K and i have a problem. when i press on the gas usually at a more lower rpm and higher speeds (50 + mph) the car pulls to the right. when i let go of the gas the car kinda snaps back to the left. anybody have any ideas as to what might cause the problem?
thanks
Old Oct 11, 2007 | 04:33 PM
Pitcru's Avatar
I just went all through that problem only it was worse at higher speeds and mine pulled to the left. Things to check - tire pressure, alignment and tires. My problem turned out to be the brand new tires. Reort back on what you check.
Pitcru
Old Oct 11, 2007 | 05:04 PM
negcamber's Avatar
The stook is very sensitive to tire pressure...also to tire size, and alignment.
Old Oct 11, 2007 | 06:04 PM
spa01s2k's Avatar
with the other guys. Check your air pressure first, this is most often the cause a car pulling one way or the other. Check your tire wear too. What kind of tires do you have?
Old Oct 11, 2007 | 08:15 PM
skibum's Avatar
I had the same problem and it was tire pressure. Both sides looked even but when I put the gauge to it, one tire was low about 12psi.
xchino
Jul 30, 2012 11:40 PM
Jaydem
Feb 14, 2006 08:57 AM
kuni
Dec 6, 2003 01:19 AM
njs2k
Jun 10, 2002 05:18 PM
Mclaren
Apr 1, 2002 12:14 PM
