Suspension problem
Hey guys i just bought myself a 01 S2K and i have a problem. when i press on the gas usually at a more lower rpm and higher speeds (50 + mph) the car pulls to the right. when i let go of the gas the car kinda snaps back to the left. anybody have any ideas as to what might cause the problem?
thanks
thanks
I just went all through that problem only it was worse at higher speeds and mine pulled to the left. Things to check - tire pressure, alignment and tires. My problem turned out to be the brand new tires. Reort back on what you check.
Pitcru
Pitcru
xchino
Jul 30, 2012 11:40 PM
kuni
Dec 6, 2003 01:19 AM
with the other guys. Check your air pressure first, this is most often the cause a car pulling one way or the other. Check your tire wear too. What kind of tires do you have?
