Swapping CV joints on Propeller shaft
Old Mar 8, 2021 | 06:02 PM
  #21
Car Analogy's Avatar
Originally Posted by Slowcrash_101
They're the same length and same bolt spacing and pattern, the lids are different not 100% sure it would accept the s2k lid because the porsche factory one fits inside the CV and our lid fits over it.
2006-2014 MY porsche cayenne awd doesn't matter turbo or whatever. The replacement ones are like $250 or about $100 more than a used Honda OEM ones. New Honda oem ones are ~$1k. U joint conversion is like 550.
Ok, still trying to fully understand. The lids are different, and likely won't swap. Splines are different, so can't swap the cv. But length and bolt pattern where it mounts to trans and diff are the same, so that means its a direct bolt in, correct?
Can't swap parts, but can swap entire propshaft?
Old Mar 9, 2021 | 02:37 AM
  #22
Slowcrash_101's Avatar
Not sure if the swap will work because of the lids. If you can slap the Honda lid, then yes it should work.
rikhemi
May 21, 2011 03:56 PM
chris2k03
Sep 23, 2008 03:59 PM
djpepsi
Aug 12, 2008 10:46 AM
RobsS2K
Aug 31, 2007 07:37 AM
Asura
Jul 22, 2005 05:45 AM
