Switching from natural to synthetic?
Old 04-13-2011, 04:11 PM
la_fever323's Avatar
Default Switching from natural to synthetic?
I'm about to do an oil change on my S that is currently running on natural oil. I want to put in synthetic, is there anything special that I have to do? or is it the same conventional oil change?
Old 04-13-2011, 04:55 PM
redlineracing's Avatar
Should be the same.I would just let it drain longer to get as much of the old oil out.Do the filter while you're at it.
I run Amsoil 0-30 and Wix filters in all my cars.My 03S likes the Wix #51334.
\rlr
carolina
Old 04-14-2011, 07:46 AM
the_catalyst's Avatar
Yep same procedure, but I maneuvered the jacks so that I could drain as much as possible & left it sitting longer than usual.
Have fun!
Old 04-14-2011, 08:30 AM
gtg749m's Avatar
Something I do with most fluid changes, and I'm not sure how much it helps, is once the oil is entirely drained, I dump in the new stuff. In your case, some synthetic oil in hopes that it flushes out a little bit more of the old stuff and let that drain out.
Old 04-14-2011, 09:38 AM
chuhsi's Avatar
same. i wouldn't bother doing any special draining. a little conventional oil mixed with almost all synthetic is fine.
Old 07-14-2019, 05:31 AM
Chuck S's Avatar
Received 1,138 Likes on 1,001 Posts
Mix of conventional and synthetic is fine. Some "synthetic" engine oil is actually a blend.
You can't drain all the oil anyway, unless you use paper towels and q-tips inside the engine. The engine holds 5.6 L (5.9 US qt) and a full oil and filter change only uses 4.8 L (5.1 US qt) to there's most of a liter or quart that doesn't come out.
-- Chuck
Realized this is an 8-year old thread after typing all this!
Old 07-14-2019, 04:56 PM
rrounds's Avatar
8 year bump
Old 07-14-2019, 07:15 PM
Langelo DeMysterioso's Avatar
Old 07-16-2019, 10:13 PM
jyeung528's Avatar
i'd recommend using pennzoil platinum, which is a group 3 liquid to gas full synthetic, as i may want to avoid pao in some synthetic oils.
Old 07-18-2019, 08:13 AM
S2000_916's Avatar
i agree best oil, track tested .
UberDuper
08-18-2015 10:18 PM
lunardeathgod
10-06-2013 02:31 PM
shotgun2224
24
03-29-2012 06:22 PM
ihavenosn16
10-01-2006 12:25 PM
Pie_n_Chips
01-28-2005 03:58 AM
Quick Reply: Switching from natural to synthetic?
