Symptoms of A Bad Propeller Shaft
Old Aug 11, 2012 | 11:32 AM
zeroptzero's Avatar
Default Symptoms of A Bad Propeller Shaft
I've noticed some light grease stains in the tranny tunnel area, it is in line with the front propeller shaft C/V joint mount. I'm curious how you know if your propeller shaft C/V is bad ?, can you feel added vibration or noise ?. Should I plan on dismantling the prop. shaft or just look for a replacement ?. The amount of grease seems light at this point. Thanks for any replies.
Old Aug 11, 2012 | 11:43 AM
MP2k's Avatar
Mine has had a pretty good buildup there for a long time. Maybe 50k+ miles. I've been waiting to see if any symptoms develop, but it's been fine.
Old Aug 11, 2012 | 12:03 PM
zeroptzero's Avatar
Thanks for the reply, that is good to know, mine is very light, maybe I can get some more life out of it then if yours has been fine for that long. Thanks for the info.
Old Aug 11, 2012 | 03:48 PM
zeroptzero's Avatar
Originally Posted by hecash
Mine began to lightly vibrate under heavy acceleration starting at, say, 4-5K rpm. It lasted a long time but I should have replaced it as soon as I noticed the vibration because when it finally went, it took my pilot bearing with it. So, instead of just having to unbolt an old shaft and re-bolt a new shaft, I had to pull the trans, PP, clutch disc, and flywheel to replace the pilot bearing. While I had the clutch out I did a new PP, disc, release bearing and guide as well as resurface the flywheel.
I got a 2007 drive shaft with 21K miles on it and a 90-day guarantee from a salvage yard on www.car-part.com for $210 shipped to my house. It's working beautifully.
Thanks for the info Hecash, I'll keep an eye out for vibrations, I may try to find a good used piece for the future.
mtbtorrent
May 26, 2017 08:17 PM
shanepotter
Sep 25, 2015 04:11 PM
jor-don
Jun 16, 2014 07:43 AM
Jrse7en
May 2, 2011 08:37 AM
starchland
Jun 8, 2010 05:26 PM
