T-stat. replacement Q
Old May 2, 2005 | 09:00 AM
sebrings2k's Avatar
Default T-stat. replacement Q
Is there such a thing and if so can it be reused or does it need to be replaced when you swap out t-stats?
Old May 2, 2005 | 08:09 PM
dhayner's Avatar
There is a rubber gasket. The book says to replace it, but I have no first-hand experience here.
Old May 2, 2005 | 08:17 PM
moparacker's Avatar
Its a nice, thick o-ring gasket. As long you don't damage it while doing the install, it can be reused.
Old May 2, 2005 | 08:22 PM
Slows2k's Avatar
A new thermostat should come with a new gasket. The gasket has "keys" that allow it to be installed 1 way only. As long as you don't tear up the old one, you'll be able to reuse it. Moved to UTH as well.
Old May 3, 2005 | 03:48 AM
hondamanwill's Avatar
If the gasket is still soft and flexable it can be reused.
Matty_Vr6
Feb 5, 2013 05:14 PM
baldy2007
Mar 3, 2009 01:22 AM
FIdreaming
Aug 16, 2006 09:29 AM
parks2000
May 15, 2006 10:50 AM
Asura
Aug 19, 2005 07:19 PM
