TCT Question
Old Sep 9, 2022 | 05:45 AM
fizzle's Avatar
Default TCT Question
Hey guys and girls, got a quick question regarding my 04's TCT.
There's been a ticking noise coming from the car sometimes on idle ove the past year. I don't drive the car much so didn't pay much attention to it because the TCT was replaced with an OEM unit 4 years ago. In that time the car has covered between 15 to 20k miles. Since the car is making ticking noise now, which I'm pretty sure is TCT related, I wanted to ask your thoughts on what could cause the TCT to wear out so soon? Just in case I should be replacing anything else alongside the TCT, which I will upgrade to a billman/ballade item
Many thanks for your time and help
Old Sep 9, 2022 | 06:17 AM
Save the Manual Wagons!'s Avatar
If you replace the TCT, holy crap, don't waste your money on Ballade. Get a Billman.
There is nothing else to do "while you're in there" replacing the TCT. It's an easy <10 minute job. I suppose you could replace your VTEC gasket, but you could also just do it later...
Are you sure the ticking is the TCT? I can never tell all those noises apart. Have you checked valve clearance? It doesn't hurt to do that every ~50k even though the owner's manual says 105k. Especially if you don't know the history of the car. My exhaust valves were all (intentionally?) set too tight. It seemed too consistent for them to have all randomly tightened up to .008".
As far as the TCT wearing out, I think the OEM unit is just prone to failure. But 15-20k does sound very low.
Old Sep 9, 2022 | 07:02 AM
dwb993's Avatar
Also check your belt tensioner pulley bearing. LHT sells just the bearing, if you are inclined to DIY the replacement. If not, you can buy the whole tensioner unit from Honda.
Old Sep 9, 2022 | 07:58 AM
fizzle's Avatar
Yeah man valve clearances were done 30k miles ago
Old Sep 9, 2022 | 10:25 PM
silenc3x's Avatar
I know people don't like Alex, and you can find plenty of stories on here, but their TCT is a completely acceptable product. Not everyone wants to send Billman their TCTs for a core exchange. I've had a Ballade TCT for like 6 years without issue.
Old Sep 10, 2022 | 07:20 AM
Slowcrash_101's Avatar
The TCT doesn't wear out, the guides and chain do. A small amount of chain stretch and guide wear will require more tension from the TCT. The replacement TCTs solve this issue by putting the piston slightly closer to the guide and increasing oil flow to the unit. You can tune the TCT, the unit has a bypass valve that can be adjusted, but ain't nobody got time for that.
Old Sep 11, 2022 | 03:58 AM
Mr.Matchbox's Avatar
Sorry, but the Bypass valve can not be adjusted. It´s a unit with a ball and spring inside, crimped close from the Factory. Exactly like the Banjo Bolts for the piston oil squirters.
The Bypass valve unit is then screwed into the TCT boby wich is also crimped so that the Bypass valve dont come loose.
You could screw it out of the TCT Body, that´s all.
On could also consider to buy the BLOX https://www.s2ki.com/forums/s2000-mo...w-tct-1199207/ or the TODA TCT.
Old Sep 11, 2022 | 05:42 AM
stock06's Avatar
Default VIDEO….
Hello Fizzle,
Not sure how Billman handles shipping out of USA. However, if it were me, I would make a video of starting the car and post that. Someone would be able to better diagnosis your issue.
Have a good day and best of luck to you!
Old Sep 11, 2022 | 07:43 AM
Billman do not ship his TCT outside the USA. When you live outside the USA and dont have relatives in the USA, you simply have to buy one of the alternatives i have listed above.
Old Sep 11, 2022 | 08:27 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Botttom line is chain tension, that’s it.
Post a video of the noise, 4 feet from the front of the car, hood closed.
