TCT replacing + chain and guides?
Old Nov 27, 2013 | 08:20 AM
Judgee's Avatar
Default TCT replacing + chain and guides?
Hi, I recently had my valve clearances adjusted after thinking that was the tapping. Ends up being that it's apparently the TCT, I've been told I can just change the TCT and it'll be fine but also been told it's best too change the chain and guides aswell? I believe it's a fair bit more work changing ye chain and guides but pretty simple to just change the TCT so if I can do that then I will. Car is just about to hit 80,000.
Any help appreciated
Old Dec 10, 2013 | 10:37 AM
BLAQ&GREYs2k's Avatar
I rebuild TCT's for very cheap. Did you still need this fixed?
Old Dec 10, 2013 | 01:19 PM
Car Analogy's Avatar
Don't waste your time and money changing the internal parts, chain and guide. Replace these when (if) you ever need to rebuild the motor. Its the tensioner that causes the noise.
Unless you drove it a long time with bad tensioner, your chain and guide should be fine.
Old Dec 10, 2013 | 01:20 PM
sowman's Avatar
I would just do the TCT change.
Old Dec 11, 2013 | 10:59 AM
s2000Junky's Avatar
Exactly
Old Dec 11, 2013 | 12:50 PM
first-s2k's Avatar
Hit up this member: "Billman250" for a new modified tensioner which is guaranteed for life.
Bobby Type R
Jun 22, 2015 01:42 AM
gdmedic
Dec 4, 2009 06:51 PM
strar8
Sep 19, 2008 01:39 AM
woo
Oct 16, 2007 05:35 AM
pikkashoe
Jul 9, 2006 08:13 PM
