Temp reading
Old Aug 19, 2011 | 07:02 PM
fernando.'s Avatar
Originally Posted by SpitfireS
Do the radiator hoses get hot after a while?
Do they also feel firm when they're hot, IOW is there pressure in the coolant system?
Do you get heat into the interior?
Does the engine go into VTEC above ~ 6000 rpm?
Does the engine rev above 6000 rpm at all?
As far as I know an OBDII reader will show what the ECU detects, not what the cluster will display (if there is a difference between them).
I'm sorry to bump this thread but I'm having the same problem.
To all the questions you just asked, my answer is yes to all of them.
Old Aug 22, 2011 | 05:35 AM
SpitfireS's Avatar
And what about connecting an OBDII scanner?
What engine coolant temp did it detect?
It also detects (mine does) air intake temp.
Something to compare it with.
Old Jan 28, 2021 | 09:47 AM
Dustin Bruhn's Avatar
The CTS Billman mentioned is #2
Thermostat #7
i’m having this problem where my car does not go above 6000 RPMs and I am not getting more than two bars on the temperature gage do you have an idea what it could be? I’ve been trying to figure this out for weeks but I am no mechanic and I’ve researched everything I can I didnt want to take it to the Honda shop by me because they are scam artists
Old Jan 28, 2021 | 10:50 AM
engifineer's Avatar
Any recent work, (replacing coolant or anything else)?
Is the check engine light on, and if so, have you pulled the codes?
VTEC will not engage if the temp is not high enough. Should still rev higher but will not go into VTEC.
Old Jan 28, 2021 | 12:20 PM
No check engine light but I did go ahead and scan it it and it was throwing a p0411 code.
Also my car usually doesn’t get above 2 bars on my temp gauge no matter how long it’s warmed up. I’ve let it warm up for 15+ min and the only way it usually reaches 3 bars is when I drive it for a while.
Old Jan 30, 2021 | 01:51 PM
Slowcrash_101's Avatar
That almost sounds like a stuck open thermostat. p0411 is for the air pump? Have you checked your vacuum lines?
DxC
Mar 21, 2015 07:04 PM
1SlowSi
Sep 13, 2013 05:42 AM
yzfr6avid
Jan 11, 2011 02:51 PM
devilsky1
Apr 30, 2010 02:55 PM
