Test pipes and Emissions Testing
Old Jul 20, 2005 | 07:47 PM
efthimios's Avatar
Default Test pipes and Emissions Testing
If I do not have a CEL (spark plug fouler extension), and no one was to look underneath will it pass?
Old Jul 20, 2005 | 08:19 PM
Slows2k's Avatar
It depends on your state's inspection requirements. If a visual is required, you'll fail.
Old Jul 20, 2005 | 08:25 PM
efthimios's Avatar
without the visual part...if it appears to be a cat... has the heat shields over it....just questioning everything else minus the visual
Old Jul 20, 2005 | 09:13 PM
Slows2k's Avatar
If they look close, you can tell it's not a convertor. Emmisions laws and enforcement vary so much between states there is no telling, you could run into the inspector that goes over every detail or the guy that just fills out the paperwork and doesn't actually check anything.
Old Jul 21, 2005 | 04:42 AM
efthimios's Avatar
here they hook it up....and at the most they use a mirror with a long handle so they don't even have to bend over
Old Jul 21, 2005 | 07:17 AM
stefluva's Avatar
Im in MD and i'm going for mine tomorrow with a test pipe so i'll let u know if it passes. They don't do visual inspection here.
Old Jul 21, 2005 | 08:21 AM
efthimios's Avatar
thanx
Old Jul 21, 2005 | 08:25 AM
Ro_Ja Boy's Avatar
Please do. I have been wondering this as well as my smog test for registration will be coming up soon. They dont do any type of visual inspection. Just hook it up and youre done. I have no CEL either and hope that I wont have to change my test pipe back. I guess I will try it and if i fail I will just put the cat back in. Thanks for asking this Tim!
Ryan
Old Jul 21, 2005 | 11:40 AM
papa5murf's Avatar
i don't think yoiu'll pass smog if you have a test pipe....
Old Jul 21, 2005 | 11:41 AM
papa5murf's Avatar
as for you... if your car is low enough and won't get over the rollers they'll pass you..
