Is there a trick to this?
Old Aug 1, 2008 | 09:49 AM
  #21
Voodoo_S2K's Avatar
Soak with Liquid Wrench/PB/or similar. Put a good socket on it and use some muscles. If it doesn't come out, it's frozen on and you can either cut it off, or try using a nice big impact gun.
Old Aug 1, 2008 | 10:50 AM
  #22
jimreaper's Avatar
Those bolts are a bitch. Use a "ghetto" pipe. Slide a long pipe over the ratchet handle. This creates a lot of torque with little effort. Worked for me. Good luck.
Old Aug 5, 2008 | 12:04 AM
  #23
danielk1's Avatar
^^ yeah like a breaker bar. ghetto pipe at the home depot is only like 3 bux!!
Old Aug 5, 2008 | 02:01 AM
  #24
s2k_dreams's Avatar
Originally Posted by shotiable,Jul 31 2008, 09:47 AM
and this is a noob question but what does PB stand for.
Peanut Butter!
Old Aug 5, 2008 | 04:44 PM
  #25
shotiable's Avatar
thankyou for the responses everyone!
special thanks to my gf and my buddy who helped me install this... i brought in my buddy today to try and get the bolt off i told him to "prove his manly-ness and take that shit off" well we ended up going with the rubber mallet from wal mart.. 2.97+tax and it got the bolts off with no problem
now i'm happily polluting the air with my emissions. i feel a slight bit better pull and i'm not throwing a CEL yet (knocks on wood). the sound is similar to blowing through a hollow pipe... well duh... the test pipe is essentially that. someone confirm this sound with me. after the install i listened for hissing sounds which would be air leaks but did not hear any... so guys... am i good with this?
negcamber- i love harbor freight i got my tools from there
EDIT: to add to this if someone is reading this and cares about the weight, i did weigh it. stock cat is 10 lbs and the invidia 70mm test pipe with 2 antifoulers are 4 lbs. if you want proof i have pics.
Old Aug 5, 2008 | 04:45 PM
  #26
shotiable's Avatar
special thanks again to my gf for buying me this awesome gift... now you know it pollutes the environment buwahhahahahaha!!!!
on that note, i dont notice the smell so much when i'm outside in open air... its only bad in the garage.
Old Aug 5, 2008 | 08:33 PM
  #27
chuhsi's Avatar
The key is PB Liquid Wrench. Spray...wait a few hours..then spray...wait about 15 minutes. All bolts come off very easy.
WD 40 does NOT work.
Old Aug 6, 2008 | 06:30 PM
  #28
frofro24's Avatar
I know you already got your test pipe on but if it is not too much of a hassle you should take the bolts back out and throw some anti seiz on them. That way if you ever have to remove them, they should come off pretty easy... I am a anti seiz whore, especially on exhaust systems...
Old Aug 6, 2008 | 06:40 PM
  #29
a_zepeda926's Avatar
dont just listen for an exhaust leak as i didnt know i had one by sound. when the car is cold, start it up, run around and feel around the piping on all sides to ensure all the gaskets sealed properly.
ryanfeldman
Oct 18, 2009 02:19 PM
s2kbtos
Mar 10, 2009 01:10 PM
mxt_77
Jan 31, 2008 06:08 AM
HondaS
Jan 22, 2008 09:36 AM
duff0000
May 5, 2007 04:02 PM
