Threadlocker or anti-seize?
Old Jul 3, 2016 | 09:48 PM
calvinnnnn's Avatar
Default Threadlocker or anti-seize?
So I'm getting ready to replace the OEM cat with a Berk HFC and I'm curious as to what applications warrant the use of anti-seize vs threadlocker. I know threadlocker is typically used where there is extreme vibrations and to prevent galvanic corrosion and anti-seize is mainly for dissimilar metals and high-temperature applications.
I imagine the bolts for the HFC would be under extreme vibrations as well as fitting the bill for a high-temp application. In this case, I assume anti-seize would work better but can that cause the bolts to loosen up over time due to vibration?
Old Jul 3, 2016 | 10:33 PM
S_DosMil's Avatar
I think I went with anti seize because it comes on the O2 sensors but who knows if that's right. Just my .02 cents.
Old Jul 3, 2016 | 10:41 PM
flanders's Avatar
Don't think there is any threadlocker that handles the heat around that area.
Use antiseize and serrated flange nuts, or regular nuts with nord-lock or spring washers.
Old Jul 4, 2016 | 07:31 AM
Chuck S's Avatar
The cat will come with new lock nuts and bolts. Just tighten them. To spec. I used new Honda spring bolts at the header.
-- Chuck
Old Jul 4, 2016 | 08:11 AM
zeroptzero's Avatar
I use copper anti-seize on all of the bolts and 02 sensors around the header and cat and exhaust. It might help with future removal.
solitarycheese
Oct 12, 2018 03:09 PM
POG
Jun 7, 2013 12:12 PM
manuelisfun
Jul 31, 2010 09:08 PM
xasrielx
Jan 31, 2010 07:25 AM
Si2k
May 6, 2007 04:10 AM
