Throttle Position Sensor signal DBW
Old 09-01-2010, 01:53 PM
deibit's Avatar
Default Throttle Position Sensor signal DBW
Hi..
I'm trying to guess where to find the TPS wire on a DBW S2000 (MY08)
The sensor is not located where the non-DBW sensor is located.. but I assume that somehow the TPS information is needed and that the signal should be available somewhere
What I need is a 0..5V signal (5V full open and 0 full closed for example)
I need to it to tap it into a Innovate LMA-3 Interface.
Any help would be appreciated. I have tried to used the search but I did not find a direct answer to it.
Thanks!
Old 09-01-2010, 11:56 PM
deibit's Avatar
I have "found" this sensor
it's not really a TPS but a "accelerator pedal position sensor", so I suppose that this sensor is used by the ECU to decide how much to open or to close the throttle body..
The TB itself must have somewhere a wire that indicates how much the TB should be opened or closed.. (that's what I am searching)
But I don't have any DBW TB wiring diagram (or the accelerator pedal sensor).. does someone have it? (Helm's manual maybe?)
Old 09-02-2010, 08:54 AM
Croc's Avatar
i'm not sure what you mena but at those pictures this black thing wi the sicket is throttle motor:
maybe you can tap it it.
Old 09-02-2010, 12:52 PM
deibit's Avatar
yeah.. but which of each of the 6 wires does what?
(i need the pinout diagram...)
Old 09-03-2010, 09:11 AM
Croc's Avatar
later i will look at the ETM and tell you.
Old 09-03-2010, 10:38 AM
R1_Pilot's Avatar
get a voltmeter and check the voltage signal while someone presses on the gas pedal. Check every pin ...
Thats a start.
J
Old 09-05-2010, 07:48 AM
Croc's Avatar
all the info here:
http://sites.google.com/site/crocweb/Home/...achine3/various
enjoy
macr88
Engine
01-21-2010 11:13 AM
DeadZero
Socal Swap Meet
06-18-2009 07:16 AM
Nametaek3n
02-04-2009 03:05 PM
Spitlist
03-07-2007 10:29 PM
TypeR1159
03-25-2003 04:30 PM
Quick Reply: Throttle Position Sensor signal DBW
