time to change engine coolant
Originally Posted by vtec9,Jun 27 2006, 06:06 AM
now I'm doing it at one year..
Oh, if you guys with older cars haven't done so, you might be well advised to put in a new thermostat, too.
Originally Posted by SenderGreen,May 5 2006, 12:08 AM
I have read;
Type I = Green
Type II (Factory fill) = Green
Type II (off the shelf) = Blue
I have a couple jugs of Type II, but haven't opened them yet so I don't know if it is blue or green.
Type I = Green
It is recommended that you either stick with a consistent known coolant for top off and changes or flush the system to switch to a different one. If you must add liquid to an unknown mix, distilled water can be used but remember it is diluting the anti-freeze and anti-corrosion capabilities.
Originally Posted by xviper,Jun 27 2006, 11:39 AM
Not really necessary to do it every year. I believe when Honda stipulated every 2 years thereafter, they were already being conservative and "on the safe side". Personally, I flushed mine out really well and switched to an aluminum compatable "long life" coolant at 3 years. This should hold me for 5 years at a time.
