Tips on installing SS brake lines
Old Jan 26, 2004 | 03:58 PM
S2WOOOW's Avatar
Default Tips on installing SS brake lines
I'm confident I can install the new lines, but I'm worried about the mess it will make. Once the old line is removed, do I have to worry about fluid running out of the line? I don't want 4 puddles of brake fluid on my garage floor.
Also I'm changing to a different brake fluid, do I have to worry about purging the ABS pump? Or is just the standard brake bleeding process good enough?
Old Jan 26, 2004 | 04:54 PM
darkknight1999's Avatar
Its messy but just put a $2.00 oil change pal on the floor under the lines as you change them, you'll be fine. Just make sure you have plenty of extra fluid to bleed those babies once your done with the install.
Old Jan 28, 2004 | 09:55 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Another tip....don't let the master cyl run empty, you don't want to bleed this system from scratch.
Old Jan 28, 2004 | 10:37 AM
thats a VERY good point!
Old Jan 28, 2004 | 12:42 PM
Intrepid175's Avatar
Yes it is! And, be VERY careful to protect the paint when you handling an open bottle of brake fluid around the car. It's one of the best paint strippers I've ever seen!
Drive Safe,
Steve R.
Old Jan 28, 2004 | 02:10 PM
Billman250's Avatar
Top Answer: 1
[QUOTE]Originally posted by Intrepid175
Yes it is!
Old Jan 28, 2004 | 02:48 PM
JDMwhore's Avatar
One other thing, install the stainless line to the hard line on the car before the fitting on the brake caliper. By the time you get the brake caliper fitting tight the line will have filled with some fluid and you will have less air in the line. Id wear some rubber gloves too, that stuff is pretty harsh to your hands.
Old Jan 30, 2004 | 10:02 PM
S2WOOOW's Avatar
Thanks for all the tips. The installation went well. I did make a little mess. I was catching the fluid dribbling from the calipers into a soup can. When I tried to pick it up wearing latex gloves with a little coating of brake fluid on, the can just slipped out of my grip. Brake fluid on latex gloves make things very slippery. I didn't get fluid on any paint except on the brackets.
Only problem was that the clips for holding the top of the line to the brackets were very loose. I had to use the old clips. Helms specifically states to use new ones, so I may try to get some Honda clips.
Old Apr 2, 2004 | 05:35 PM
Speedster's Avatar
Does anyone have the full installation guide for installing SS? I need the laymen's version. I have no idea what anything is what unless I see it. Thanks.
Billman250
Jan 22, 2021 03:51 PM
C3wrb
Apr 10, 2014 02:07 PM
J.T
Jul 11, 2007 08:24 PM
owenxguo
Apr 7, 2005 09:02 PM
revhard
Nov 15, 2001 10:34 AM
