Toda Header touching Engine Mount
Old Jul 31, 2007 | 12:58 PM
alejo's Avatar
Default Toda Header touching Engine Mount
The header was just installed, I have not dropped the car from the jacks and driven it yet because I can see the header and the engine mount touching.
Any suggestions?
Old Jul 31, 2007 | 01:16 PM
glagola1's Avatar
Check that your motor mounts are not worn out. They may look OK at first glance but if they were out your motor will sit lower in the engine bay by at least 3/4". Now if the header is hitting a part of the mount that is hard fastened to the motor then I don't know what to tell you.
Old Jul 31, 2007 | 01:18 PM
alejo's Avatar
/\ don't think it's the mount being lower because the header is touching the top of it - if it was higher the header would not even fit...
I neglected to mention that the header is a Toda with the engine mount bracket snapped off - nonethelss I believe that mount is not really needed....
Old Jul 31, 2007 | 05:49 PM
freq's Avatar
Is the header brand new or used?
Old Jul 31, 2007 | 05:52 PM
alejo's Avatar
used
Old Jul 31, 2007 | 06:11 PM
S2KPUDDYDAD's Avatar
Maybe the header is bent, that is why the lower engine mount is broke/missing.....just a thought
good luck
Old Jul 31, 2007 | 06:14 PM
alejo's Avatar
good luck
maybe
looks fine though
S2KiChad
Nov 24, 2015 11:09 PM
s2000maniac
Sep 21, 2011 04:04 PM
tragicfate
Mar 12, 2010 03:11 PM
skibum
Jul 2, 2009 06:23 AM
mikecl713
Mar 14, 2004 02:07 PM
