Tranny Filler Bolt Help
Today I attempt to snap loose the tranny filler bolt again, yes this is the second time, but I wasn't able to snap it loose. I bench press 200lbs and curl 30lbs and I wasn't able to snap it. How strong do you have to be? Does longer ratchet help? My ratchet is about 7 or 9 inches long. Any idea on how to snap it loose? Please help.
Thanks for the correction nightcrawler7188
It shouldn't be that tough at all to snap the bolt off. I know this is obvious but make sure you're turning it the right away. Counter-clockwise to loosen the bolt.
slightly2ned
58
11-04-2008 08:35 PM
