Tranny Filler Bolt Help
Old 10-05-2007, 12:32 PM
rocrfella's Avatar
Default Tranny Filler Bolt Help
Today I attempt to snap loose the tranny filler bolt again, yes this is the second time, but I wasn't able to snap it loose. I bench press 200lbs and curl 30lbs and I wasn't able to snap it. How strong do you have to be? Does longer ratchet help? My ratchet is about 7 or 9 inches long. Any idea on how to snap it loose? Please help.
Thanks for the correction nightcrawler7188
Old 10-05-2007, 12:33 PM
nightcrawler7188's Avatar
you mean raTCHet lol
use a longer ratchet, or attach a pole/breaker bar to the end of it. it shouldn't be that hard.
Old 10-05-2007, 12:41 PM
and yes, if you increase the length of the lever you use to turn the bolt, you will significantly increase the torque you exert on it.
Torque = Force x Length
Old 10-05-2007, 02:51 PM
daktruckie99's Avatar
I put about a 8/9 inch ratchet on it and then swung a breaker bar into the wrench to shock it loose. Much easier that was than doing it with your hands.
Old 10-05-2007, 02:59 PM
jzz30's Avatar
or just whack the wrench with a hammer.
Old 10-05-2007, 03:06 PM
S2KenC's Avatar
It shouldn't be that tough at all to snap the bolt off. I know this is obvious but make sure you're turning it the right away. Counter-clockwise to loosen the bolt.
Old 10-05-2007, 07:47 PM
SIIK2NR's Avatar
use another heavy wrench to tap the end of the connected wrench or socket wrench.....it will break free much easier than applying constant force.
Old 10-06-2007, 06:29 AM
Tee-Dub's Avatar
I'm getting ready to service mine on my 05. Is it really this hard to break free? Isn't the torque spec only about 30ft/lbs for that bolt?
Old 10-06-2007, 06:35 AM
it isn't hard, but rocrfellawas just having trouble
slightly2ned
58
11-04-2008 08:35 PM
driftnby
02-16-2008 02:08 PM
fadiss2k
02-06-2007 04:49 PM
mtm584
12-19-2003 05:25 PM
Saab9-3
04-24-2003 07:58 PM
Quick Reply: Tranny Filler Bolt Help
