Tranny problem
Old Aug 17, 2009 | 10:07 PM
julianaa's Avatar
Default Tranny problem
Ok so a while back I bought a used tranny, My old tranny went out... So I had the new tranny put in and now when I drive for a a distance 20 miles plus and i mean like highway driving the tranny seems to get sticky... like to come out of 6th gear i have to use some strength. And than right after going from 2nd to 3rd is kind hard and KLUNKS.... anyone else experience this? I have tried searching and didnt really find anything.... Thanks!
Old Aug 17, 2009 | 10:15 PM
rossco's Avatar
i would first check the trans fluid, what type of fluid are you using? i use honda mtf the new formula. seems like a lubrication problem, i would also check the clutch hydraulic system for leaks or air, clutch slave and master. hope you fix the problem.
Old Aug 18, 2009 | 02:01 AM
learning03's Avatar
My AP1 does this clunk, the way around it for me is not to rush the shift but to take a split of a second then shift. No clunk, goes smooth even when cold. However clutch fluid change would be a good idea, as well as checking the slave and master clutch cylinder for leaks.
Old Aug 18, 2009 | 03:31 AM
julianaa's Avatar
yeah the fluid was an idea and i changed it i used honda MTF, i guess ill check the clutch slave and master now... thanks for the help guys...
Belkin623
Feb 2, 2015 06:49 AM
Frez2k
Oct 8, 2010 08:25 AM
JakLaw
Sep 20, 2006 08:46 PM
fadiss2k
Apr 27, 2006 09:11 AM
ken reich
Oct 17, 2004 08:40 PM
