Transmission Frustration
Old Jul 15, 2004 | 02:04 PM
ken reich's Avatar
Default Transmission Frustration
my 01 S has 6500 kms on it, and i have one bitch , 3rd gear engagement is a less than smooth, after the first few shifts into 3rd the shifter wants to push back against the palm of my hand, all other gears are fine, tried redline , gm synchromesh , and mobile 1 trans fluid, still there, any suggestions, have taken it to the dealership, no answers yet?
Old Jul 15, 2004 | 02:18 PM
standard63's Avatar
Change clutch fluid? I found that by bleeding only, the clutch fluid comes out easily and clear. Pumping the pedal a few times caused all kinds of black crud to flush out of there. After that flush, felt like I had a new clutch and much better shifting.
Old Jul 15, 2004 | 02:24 PM
OverBooster's Avatar
at least your tranny fluid did not start draining out at 11,000 miles. I am still waiting to get my car back.
Old Oct 17, 2004 | 02:22 PM
SoDakS2K's Avatar
There is a TSB out for the problem you are having. The third gear (and fourth I believe) syncros need to be replaced. I know this thread is old, but in case this info helps...
Old Oct 17, 2004 | 08:08 PM
soundzero's Avatar
Changing trans fluid and and differential fluid does wonder!
Do it quick if you haven't done it.
I use GM Syncromesh for trans fluid and LE607 for diff fluid. They are awesome
Old Oct 17, 2004 | 08:40 PM
joe_s2k's Avatar
I change both tranny and diff @ every 15k mile interval.
Gotpepsi
Jun 27, 2015 05:15 PM
Belkin623
Feb 2, 2015 06:49 AM
rmk232
May 7, 2012 09:25 AM
Frez2k
Oct 8, 2010 08:25 AM
GPS2K01
Nov 15, 2007 05:11 AM
