Tranny Synchro
Old Apr 28, 2009 | 11:11 AM
chilidip
Guest
Posts: n/a
Default Tranny Synchro
So when my S2 is still cold I noticed that the 1st to 2nd gear shift appears to be a bit off. Almost like the the synchro needs work. Once it reaches normal operating temperature, the problem seems to go away.. anyone had this problem with their transmission? Any remedies? Thanks everyone.
Old Apr 28, 2009 | 11:17 AM
SpitfireS's Avatar
No.
You're the first!
Btw.. is the search broken again?
Sorry.
Old Apr 28, 2009 | 12:00 PM
thebig33tuna's Avatar
completely normal. just take it easy when its cold.
other option is different tranny fluid. i don't have this problem since switching to gm synchromesh.
Old Apr 28, 2009 | 02:51 PM
chilidip
Guest
Posts: n/a
I did see in the search engine about redline synchro issues, and general issues however did not see much relating to temperature. Thanks
Old Apr 28, 2009 | 02:54 PM
chilidip
Guest
Posts: n/a
GM synchromesh? I've used REdline MTL in my Miata before with good results however didn't realize the fluid would remedy the issue. Thanks will try that.
Old Apr 28, 2009 | 03:17 PM
lotus7racer's Avatar
Heat and cold make things or metal expand and contract.
Jap engineers calculated the tolerance when metal is cold and when metal is in operating temp.
When you just woke up, you are the mother of all the grouchy people.
Once you warm up, what happen?
Smooth and smiling huh?
Old Apr 28, 2009 | 04:38 PM
spook's Avatar
Hahah, well put.
fernando.
Dec 8, 2011 03:28 PM
CourageOO7
Jun 24, 2006 07:36 AM
bs-inc.s2k
Aug 16, 2005 12:42 AM
jwkim
Sep 30, 2004 09:47 PM
tesseract
Mar 27, 2004 02:37 PM
